25 RTD interview questions and answers for your job preparation in temperature measurement and instrumentation.
What is an RTD and how does it work?
An RTD (Resistance Temperature Detector) uses a metal’s predictable change in resistance with temperature. A constant-current source excites the element; measuring the voltage gives resistance → temperature via a curve (e.g., Callendar–Van Dusen). -
Why is platinum (Pt100/Pt1000) the industry standard?
Chemically stable, nearly linear R-T relation, repeatable, wide range (≈-200…+600 °C), and standardized (IEC 60751). Pt100 = 100 Ω at 0 °C; Pt1000 = 1000 Ω at 0 °C. -
State the temperature coefficient (α) used in IEC RTDs.
IEC 60751 platinum uses α ≈ 0.00385 Ω/Ω/°C (European curve). Older “American” curve uses α ≈ 0.003916. -
Give the Callendar–Van Dusen equation.
For platinum: R(T)=R₀[1 + A T + B T² + C(T−100)T³] (C=0 for T≥0 °C). For α=0.00385, A≈3.9083×10⁻³, B≈−5.775×10⁻⁷, C≈−4.183×10⁻¹². -
Compare Pt100 vs Pt1000.
Same curve; Pt1000 has 10× higher resistance → less lead-wire error and better SNR on long runs, but some legacy transmitters only accept Pt100. -
List common wiring configurations and when to use them.
2-wire: shortest runs, lowest accuracy (lead error).
3-wire: industrial standard; assumes equal lead resistance to cancel most error.
4-wire: highest precision; eliminates lead error by measuring sense leads separately. -
What is self-heating and how do you minimize it?
Sensor warms due to I²R power from excitation current, biasing the reading high. Use lower excitation current (e.g., 0.1–1 mA for Pt100), ensure good thermal contact, and avoid still air. -
Typical resistance change per °C for Pt100 and Pt1000?
Pt100: ~0.385 Ω/°C near 0 °C. Pt1000: ~3.85 Ω/°C. -
Wire-wound vs thin-film elements—differences?
Wire-wound: best stability and shock resistance at high temps; costlier, slower response.
Thin-film: small, fast, cheaper; slightly more drift at high temps and vibration. -
Accuracy classes per IEC 60751?
Common: Class A ±(0.15 + 0.002|t|) °C and Class B ±(0.30 + 0.005|t|) °C. (Also 1/3 B, 1/10 B used by vendors for tighter build tolerances.) -
What are t₆₃ and t₉₀ response times?
Time to reach 63%/90% of a step change. Specified with medium and flow (e.g., water in motion vs air). Slim tips and spring-loaded inserts shorten response. -
How do you compensate lead-wire resistance in 3-wire RTDs?
Use a bridge/measurement circuit that assumes the two same-color leads have equal resistance; subtracts them from the measurement (balanced bridge or transmitter algorithm). -
Why use an RTD transmitter (4–20 mA or HART/fieldbus) instead of direct resistance?
Linearization, lead compensation, EMI immunity, long-distance transmission, diagnostics, and standardized scaling (e.g., 4–20 mA = range). -
Typical operating range and limits for platinum RTDs?
Usable ≈ −200 to +600 °C (element dependent). Many industrial assemblies are specified for −50…+250/400 °C due to sheath, insulation, and transmitter limits. -
What is stem-conduction error and how do you reduce it?
Heat flows along the sheath to ambient, biasing the sensor. Use sufficient immersion length (rule of thumb ≥15–20× sheath OD or as per well tests) and thermowells sized for flow. -
Explain insulation resistance testing of an RTD assembly.
Measure between element leads and sheath. Typical acceptance: ≥100 MΩ at 100 V DC at ambient (check vendor spec). Low IR indicates moisture ingress or damaged MgO. -
How do you check/field-calibrate an RTD loop?
Use a dry-block or ice-point (0 °C) and a traceable reference probe, or simulate resistance with a decade box/precision calibrator at several points, then adjust transmitter. -
RTD vs thermocouple—when choose which?
RTD for accuracy, stability, and moderate ranges (−200…+600 °C); T/C for very high temps, faster response, ruggedness, or when self-powered sensing is useful. -
Common failure modes of RTDs.
Open circuit (broken element/lead), moisture reducing IR, drift from prolonged high temp, shorted sheath, loose terminal screws, and cable damage. -
Why do some plants specify “spring-loaded RTD with terminal head”?
Spring maintains tip contact in a thermowell, improving response and repeatability; head provides terminals/transmitter and environmental protection. -
What tolerance and drift should you expect over time?
Well-built Pt100 Class A may drift <0.05–0.1 °C/year near room temp; higher temps and vibration increase drift. Re-verify on critical services annually or per QA plan. -
How does vibration affect RTDs and how do you mitigate it?
Can break wire-wound elements or loosen connections. Use vibration-rated elements, mineral-insulated cables, proper well support, and avoid resonant lengths. -
What’s the impact of using copper extension wire with an RTD?
Electrically fine (it’s a resistive sensor), but lead resistance adds error unless using 3-/4-wire methods and proper compensation. -
Give a quick calculation: expected resistance of a Pt100 at 100 °C.
Approx 138.5 Ω for IEC 0.00385 curve (ΔR ≈ 38.5 Ω over 100 °C). -
Best practices when installing RTDs in thermowells.
Choose correct well material/length/bore; ensure tip contact (spring-loaded insert); use thermal compound if allowed; respect insertion length for dynamics; torque and seal correctly; route shielded cables away from noise.
