Vendor Documentation in I&C Projects (RFD)
:page_facing_up: Vendor Documentation in I&C Projects – Why RFD Matters
In instrumentation and control projects, smooth execution depends heavily on timely and complete vendor documentation.
:magnifying_glass_tilted_left: What is RFD?
RFD in simple terms: a shared list of documents that MUST come from the vendor, linked to project milestones.
:backhand_index_pointing_right: No guesswork. No β€œI thought you were doing that”.
It ensures:
:check_mark: No missing documents
:check_mark: Clear responsibilities
:check_mark: Proper tracking with timelines
:pushpin: Typical Vendor Documents
For a typical package, you need at least:
:bar_chart: Instrument datasheets
:electric_plug: Wiring / interconnection and loop drawings
:brain: Cause & effect inputs and shutdown interfaces
:desktop_computer: Panel GA, I/O list, communication/interface details
:books: Certificates, manuals, and tools/consumables list
:warning: Key Stage: Kick-off Meeting
This is where you win or lose the project control.
:bullseye: Must clarify:
:round_pushpin: Battery limits and responsibilities
:page_facing_up: Exact document list and revisions
:stopwatch: Issue sequence (Engineering, FAT, SAT requirements)
:bar_chart: Simple Tracking Method
For beginners, keep it simple:
:file_folder: One register (Excel is enough)
:white_check_mark: Document code
:white_check_mark: Title
:white_check_mark: Revision
:white_check_mark: Due date
:bar_chart: Status
:red_circle: Not received
:yellow_circle: Under review
:green_circle: Approved
:date: Review it with the vendor in every progress meeting
:light_bulb: Why RFD is Critical
If you get RFD alignment early:
:white_check_mark: Avoid late surprises
:white_check_mark: Prevent engineering delays
:white_check_mark: Reduce rework and claim discussions
Without it:
:cross_mark: Delays
:cross_mark: Missing inputs
:cross_mark: Commercial disputes
:speech_balloon: In your projects, which vendor documents are most critical during early engineering?
#instrumentation #controlsystems #engineeringprojects #projectmanagement Automation
