Question:
What is a final control element in a control loop?
Options:
A) Sensor
B) Control valve
C) Transmitter
D) Element
Correct Answer: B) Control valve
Detailed Explanation
A final control element (FCE) is the device that physically acts on the process to change the manipulated variable.
The most common example is a:
Control valve
It receives the controller output signal (e.g., 4β20 mA) and adjusts flow, pressure, level, or temperature accordingly.
Control Loop Structure
Sensor β Transmitter β Controller β Final Control Element β Process β PV
The final control element executes the controllerβs command.
A) Sensor β Measures the process variable.
C) Transmitter β Converts sensor signal into standard signal.
D) Element β Too generic; not specific.
Other Examples of Final Control Elements
- Control valve
- Variable Frequency Drive (VFD)
- Damper actuator
- Heater element
- Motor starter
