Safety Voting Logic Explained Simply (SIS / ESD Systems)
In safety systems, voting logic determines when a shutdown should occur based on signals from multiple sensors.
The goal is to balance Safety and Plant Availability
Here are the common voting logics used in industry ![]()
#1oo1 Voting Logic (One out of One)
Trip occurs if 1 sensor detects danger
Fastest response
No redundancy
Sensor failure can cause false trip
#1oo2 Voting Logic (One out of Two)
Trip occurs if any one of two sensors trips
Very sensitive protection
Higher nuisance trip possibility
Detects hazards quickly
#2oo2 Voting Logic (Two out of Two)
Both sensors must trip
Reduces false trips
More reliable decision
Slightly slower protection
#2oo3 Voting Logic (Two out of Three)
Any two sensors out of three must trip
Best balance of safety & availability
Can tolerate one faulty sensor
Widely used in critical processes
#1oo3 Voting Logic (One out of Three)
Trip occurs if any one of three sensors trips
Extremely sensitive
Fast hazard detection
Higher false trip probability
#3oo3 Voting Logic (Three out of Three)
All three sensors must trip
Very stable operation
Avoids nuisance trips
Lower safety sensitivity
#2oo4 Voting Logic (Two out of Four)
Any two sensors out of four must trip
Higher redundancy
Improved availability
Used in complex protection systems
#3oo4 Voting Logic (Three out of Four)
Three sensors must agree
Very high reliability
Fault tolerant
Used in high-risk facilities
#2oo3D Voting Logic (Diagnostic Voting)
2 out of 3 with automatic diagnostics
Detects faulty sensors
Maintains protection in degraded mode
Used in modern SIS architectures
Key Idea
Lower voting requirement → Faster protection
Higher voting requirement → Higher reliability
Most commonly used in industry?
2oo3 Voting Logic
Because it provides the best balance between safety and plant uptime.
#ProcessSafety #FunctionalSafety #Instrumentation #SIS Automation #ControlSystems #IndustrialSafety ![]()
