What is bumpless transfer in PID control?
Question:
Options:
A) Sudden output jump
B) Instant PV change
C) Noise filtering
D) Smooth mode change
:white_check_mark: Correct Answer: D) Smooth mode change
Bumpless transfer refers to a smooth transition between manual mode and automatic mode (or vice versa) without causing a sudden change in controller output.
Without bumpless transfer:
  • Switching to auto may create a large error
  • Controller output may jump suddenly
  • Process upset or instability may occur
With bumpless transfer:
  • Internal controller states (especially integral term) are aligned
  • Output continues smoothly
  • No sudden “bump” in actuator position
:repeat_button: Why It Is Important
Used during:
  • Startup
  • Maintenance
  • Commissioning
  • Operator intervention
It ensures stable operation when changing modes.
A) Sudden output jump → That is what bumpless transfer prevents.
B) Instant PV change → PV depends on process dynamics.
C) Noise filtering → That is related to derivative filtering, not mode switching.
