What is meant by a direct-acting controller?
Question:
Options:
A) PV↑ → Out↓
B) PV↑ → Out↑
C) SP↓ → Out↑
D) Err = 0
:white_check_mark: Correct Answer: B) PV↑ → Out↑
A direct-acting controller is defined by the relationship between the process variable (PV) and the controller output.
In direct action:
  • If PV increases,
  • The controller output also increases.
The output moves in the same direction as the PV.
:repeat_button: Example
Cooling system:
  • Temperature (PV) rises
  • Controller output increases
  • Cooling valve opens more
  • Temperature reduces
The controller output increases when PV increases — hence direct acting.
A) PV↑ → Out↓ → That describes reverse-acting control.
C) SP↓ → Out↑ → Direct/reverse action is defined by PV behavior, not SP.
D) Err = 0 → That describes steady-state, not controller type.
