Question:
What is meant by “closed-loop control”?
Options:
A) No feedback
B) With feedback
C) Manual mode
D) Fixed output
Correct Answer: B) With feedback
Detailed Explanation
Closed-loop control is a control system that uses feedback to automatically regulate a process.
In a closed-loop system:
- The process variable (PV) is continuously measured.
- It is compared with the setpoint (SP).
- The controller calculates the error (SP − PV).
- Corrective action is applied to reduce the error.
Because the output depends on feedback from the process, the system can automatically correct disturbances.
A) No feedback
This describes open-loop control, not closed-loop.
C) Manual mode
Manual mode bypasses automatic correction; it is not feedback-based control.
D) Fixed output
Fixed output is open-loop behavior and does not adjust based on process conditions.
Simple Understanding
Closed-loop = “Self-correcting system”
Open-loop = “Blind control system”
