What is the primary function of integral action in PID control?
Question:
Options:
A) Add damping
B) Predict error
C) Remove offset
D) Reduce gain
:white_check_mark: Correct Answer: C) Remove offset
The primary function of integral action is to eliminate steady-state error (offset).
Integral action works by accumulating error over time:
If a small error persists:
  • The integral term continues to increase
  • Controller output keeps adjusting
  • Eventually, the error becomes zero
This ensures accurate long-term control.
:repeat_button: Why It Is Necessary
In proportional-only control:
  • Some steady-state error must remain
  • Because output depends directly on error
Integral action removes that limitation.
A) Add damping → Damping is mainly provided by derivative action.
B) Predict error → That is the role of derivative action.
D) Reduce gain → Integral action does not reduce proportional gain.
