Question:
What is the process variable (PV) in a control loop?
Options:
A) Measured value
B) Controller gain
C) Desired value
D) Output limit
Correct Answer: A) Measured value
Detailed Explanation
The Process Variable (PV) is the actual measured value of the parameter being controlled.
Examples:
- Temperature in a furnace
- Pressure in a pipeline
- Flow rate in a line
- Level in a tank
The PV is:
- Measured by a sensor
- Converted by a transmitter
- Sent to the controller
The controller then compares PV with the setpoint (SP):
Error = SP - PV
B) Controller gain
Gain (Kp) is a tuning parameter, not a process measurement.
C) Desired value
That is the Setpoint (SP), not PV.
D) Output limit
Output limit refers to actuator constraints (0–100%), not the measured process.
Quick Memory
PV = Process Variable (Present Value)
SP = Set Point
