What readings should you expect to find when you measure the resistance between bases 1 and 2 of a UJT?
A. A short regardless of the polarity of the meter leads
B. A high resistance value regardless of the polarity of the meter leads
C. Approximately 15 ohms between base 1 and base 2 with the negative meter lead connected to base 1
D. Approximately 15 ohms between the two bases with the negative meter lead connected to base 2
