What will happen if the transformers working in parallel are not connected with regard to polarity?
What will happen if the transformers working in parallel are not connected with regard to polarity ?
A. The power factor of the two transformers will be different from the power factor of common load
B. Incorrect polarity will result in dead short circuit
C. The transformers will not share load in proportion to their kVA ratings
D. none of the above
