When a relay-logic Wired-NAND gate utilizing only two relays is employed in a motor control circuit ___
When a relay-logic Wired-NAND gate utilizing only two relays is employed in a motor control circuit;
The relay-logic output, taken on the common load side of the parallel-connected NC relay contacts, is zero volts only when all of the relay contacts are ______________.
A) at-rest
B) activated
C) activated or at-rest
D) none of the answers
Answer:B
