When measuring resistance between the gate, source, and drain of a depletion/enhancement type of MOSFET with the negative lead attached to the gate, what readings should you expect?
A. Both readings should be infinity
B. Both readings should be between 15 ohms and 100 ohms
C. Both readings should be approximately 1,000 ohms
D. Both readings should be less than 10 ohms
