When the knife disconnecting means in the motor-controls wiring laboratory at a given lab station is closed, the lower phase-to-neutral supply voltage can be measured to any grounded metal enclosure ___
When the knife disconnecting means in the motor-controls wiring laboratory at a given lab station is closed, the lower phase-to-neutral supply voltage can be measured to any grounded metal enclosure or other surface at either the selector switch location, the motor-starter location, or the motor location, because ____________ at the point of power supply for the wiring lab station.
A) the equipment grounding means (conductor) is connected common to the Line 1 ungrounded circuit conductor
B) the equipment grounding means (conductor) is connected common to the Line 3 ungrounded circuit conductor
C) the equipment grounding means (conductor) is connected common to the Line 2 ungrounded circuit conductor
D) the equipment grounding means (conductor) is connected common to the neutral grounded circuit conductor
Answer:D
