When two motors are controlled with a 3-position selector switch, the control or run status of the two motors are interlocked with the single switch. If both motors are to be OFF in the center position of the switch, then both sets of ___
If both motors are to be OFF in the center position of the switch, then both sets of contacts should be at-rest in their ________________ configuration.
Motor 1 is commanded to run when the switch is turned to the ________________ position.
Motor 2 is commanded to run when the switch is turned to the ________________ position.
A) NC; left; right
B) NC; right; left
C) NO; right; left
D) NO; left; right
Answer:D
