When unsoldering a MOSFET from a printed circuit board, you should avoid ___
When unsoldering a MOSFET from a printed circuit board, you should avoid using a vacuum plunger solder sucker for which of the following reasons?
A. Solder suckers can generate high electrostatic charges that can damage MOSFETs
B. Solder suckers create a vacuum that can physically damage MOSFETs
C. Solder suckers are not authorized for any type of equipment repair
D. Solder suckers require the use of a high wattage soldering iron that may damage MOSFETs
