Which of the following is an appropriate reason to use transistors instead of electron tubes?
A. Transistors are more rugged than electron tubes
B. Transistors are not as heat sensitive as electron tubes
C. Transistors are not as sensitive as electron tubes to voltage overloads
D. Transistors are capable of handling greater amounts of power than electron tubes
