Which one of the following describes a characteristic of a Geiger-Mueller radiation detector ___
Which one of the following describes a characteristic of a Geiger-Mueller radiation detector?
A. Radiation types can be identified by pulse height and duration.
B. Specific radionuclides can be identified with the use of gamma spectrometry.
C. Small variations in applied voltage will result in large changes in detector output.
D. Any type of radiation that ionizes the detector gas will produce the same magnitude detector output pulse.
