Which one of the following results from a loss of control power to a breaker supplying a motor?
A. The motor ammeter indication will be zero regardless of actual breaker position.
B. The breaker position will remotely indicate closed regardless of actual position.
C. The breaker will trip open due to the actuation of its protective trip device.
D. The charging motor will not recharge the closing spring after the breaker closes.
