Which parameter most affects RTD response time?
A. Number of wires
B. Sensor mass
C. Ambient temperature
D. Terminal type
Explanation:
The response time of an RTD is primarily affected by its sensor mass (thermal mass).
Response time is the time required for the RTD to react to a change in process temperature and reach a specified percentage of its final value.
Why Sensor Mass Matters
  • Smaller sensing elements heat up and cool down faster.
  • Larger sensing elements require more time to absorb or release heat.
  • Lower thermal mass results in faster temperature response.
For example:
  • Thin-film RTDs typically have lower mass and faster response.
  • Large wire-wound RTDs generally have higher mass and slower response.
Number of wires
  • Affects measurement accuracy and lead resistance compensation.
  • Does not significantly affect response time.
Ambient temperature
  • Influences operating conditions but is not the primary factor determining sensor response speed.
Terminal type
  • Affects wiring and installation convenience.
  • Has little impact on thermal response.
Other Factors That Influence RTD Response Time
  • Thermowell size and material
  • Sensor diameter
  • Flow velocity around the sensor
  • Installation method
  • Protective sheath thickness
Because thermal mass has the greatest influence on how quickly an RTD can respond to temperature changes, Option B (Sensor mass) is the correct answer. :white_check_mark:
