Which RTD accuracy class provides the highest accuracy?
A. Class A
B. Class B
C. Class C
D. Class D
Explanation:
According to the IEC 60751 standard, RTDs are classified into different accuracy classes based on their allowable measurement error.
Among the given options, Class A provides the highest accuracy.
RTD Accuracy Classes
Class Typical Accuracy at 0°C
Class A ±0.15°C
Class B ±0.30°C
Class C ±0.60°C
Class D ±1.20°C
The tolerance for a Class A RTD is:
Where:
  • T = Temperature in °C
This means Class A RTDs have tighter tolerances and lower measurement uncertainty than Class B, C, or D RTDs.
Why Use Class A RTDs?
:white_check_mark: Higher measurement accuracy
:white_check_mark: Better process control
:white_check_mark: Improved calibration performance
:white_check_mark: Suitable for critical industrial applications
:white_check_mark: Reduced temperature measurement uncertainty
Class A RTDs are commonly used in process industries, laboratories, pharmaceutical plants, and applications where precise temperature measurement is important.
Therefore, Option A (Class A) is the correct answer.
