Which RTD characteristic describes long-term performance?
A. Span
B. Resolution
C. Gain
D. Stability
Explanation:
Stability refers to an RTD’s ability to maintain its accuracy and resistance-temperature characteristics over a long period of time.
A highly stable RTD will produce consistent temperature measurements even after years of operation, repeated thermal cycling, and exposure to industrial process conditions.
What Stability Means
:white_check_mark: Minimal drift over time
:white_check_mark: Consistent calibration performance
:white_check_mark: Reliable long-term measurements
:white_check_mark: Reduced recalibration requirements
Why Stability is Important
In industries such as:
  • Oil & Gas
  • Power Plants
  • Pharmaceuticals
  • Chemical Processing
temperature sensors are expected to operate accurately for many years. A stable RTD ensures that measurement errors do not gradually increase due to aging or environmental effects.
Span
  • Difference between the upper and lower measurement limits.
Resolution
  • Smallest detectable change in measurement.
Gain
  • Ratio of output change to input change, commonly used in control systems.
Stability
  • Describes the ability to maintain performance and accuracy over time.
Because long-term measurement reliability is determined by how well a sensor resists drift and maintains calibration, Option D (Stability) is the correct answer. :white_check_mark:
