Which RTD wire configuration is most common in industry?
A. 2-wire
B. 3-wire
C. 4-wire
D. 5-wire
Explanation:
The 3-wire RTD configuration is the most commonly used RTD wiring method in industrial applications because it provides a good balance between accuracy and cost.
RTD Wiring Comparison
2-wire RTD
  • Simplest wiring method
  • Lowest installation cost
  • Lead wire resistance causes measurement errors
  • Suitable for short cable runs
3-wire RTD
  • Most widely used in process industries
  • Compensates for lead wire resistance
  • Good accuracy at reasonable cost
  • Commonly used with PLCs, DCSs, and temperature transmitters
4-wire RTD
  • Highest accuracy
  • Completely eliminates lead wire resistance effects
  • Typically used in laboratories and calibration systems
  • More expensive due to additional wiring
5-wire RTD
  • Not a standard configuration for most RTD applications
A typical 3-wire RTD uses two wires of the same color and one wire of a different color, allowing the transmitter or controller to compensate for lead resistance and improve measurement accuracy.
Therefore, Option B (3-wire) is the correct answer. :white_check_mark:
