Question:
Why does proportional-only control typically result in offset?
Options:
A) No reset action
B) Needs error to act
C) No D action
D) SP drives output
Correct Answer: B) Needs error to act
Detailed Explanation
In proportional-only control, the output is given by:
For the controller to produce output, error must exist.
At steady state:
- If error becomes zero ā Proportional output becomes zero
- But the process usually requires some non-zero output to maintain equilibrium
Therefore, a small error must remain to maintain the required output.
This remaining error is called steady-state offset.
Why Integral Removes Offset
Integral action accumulates error over time and continues adjusting output until error becomes zero.
Proportional action alone cannot eliminate it.
A) No reset action ā This is technically true (integral is called reset), but the fundamental reason is that proportional action requires error to produce output.
C) No D action ā Derivative does not remove offset.
D) SP drives output ā Output depends on error (SP ā PV), not SP alone.
